Can You Use Rc Leveling Kit With 3in Rc Lift?
i recently bought the RC leveling kit, and was wondering if i also bought the RC 3in kit if they could be used together? I know the redylift kit includes the strut spacer for the top and bottom, and was thinking this would be no different. If this will not work could anyone tell me how to get a little more lift out of the front so i can add a block in the rear and still be fairly level.....thanks
can you physically install it? yes
should you? NO
your tie rods and steering rack are going to be screaming at those angles. the lower balljoint is going to be maxxed out. and im skeptical that you'l get the camber aligned within specs.
how can you get more height out of the front? take off the RC 3" kit and put on a 4" suspension lift.... seriously, there arent any other options.
Since you already bought the leveling kit, the best way to get that much lift would be to add a 3" body lift. That will net you 5" of lift in the front and 3" in the rear. It will accomplish the same goal for roughly the same price, and it will allow you to avoid all of the problems Matt mentioned.
so u either have to put the spacer on the bottom or buy the spacer kit that goes on top of the strut? you cant use both no matter what? I know the redylift kit has both and gives roughly 2.5in in the front.....Maybe i should of bought the redylift kit then.
hey matt, i was wondering what kit u had in ur denali?
It's a 3" body lift.
:tear:
:tear:
Just like you told me to do :dunno:
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 518 Guests (See full list)
