Roadmaster Active Suspension
MarkD
I installed a set on a friends '00 Sierra Z71 this past weekend.  I drove it before and after, big improvement.  They really plant the rear on curves.
I ordered a set myself monday and received them today!
$229 shipped.  Definately recommend! :D
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
