Door/fender Issues
Hey guys, my drivers door started squeaking about a week ago, and I thought it was the hinges, and I went to clean and lube them I noticed that the door was rubbing the fender, and had wore some paint offsad.gif
Here's some pics:
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 768x1024.DSCN0591.jpg
You can see the gap getting smaller
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x768.DSCN0594.jpg
top of door
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x768.DSCN0596.jpg
bottom of door
Also the other side of the door has a good gap, about identical to the other side, so I'm not sure. My grandpa was kind of a big guy, and probably used the door and steering wheel to get in, so that may have wore something
What options do I have to fix it?
Door Bushings, fender adjustment, door adjustment door pins?
Does the door have slack when you open it. Open the door and pick up on the end. If its got slack then you need the bushings. The only adjustment is on the pin that the latch grabs. See the star head inside, loosen it and slide it up, down, in or out until the door (with no slack) shuts.
Here's some pics:
top of door
bottom of door
Probably bushings....... Shut the door...... Notice how high the door is, pull level only enough to unlatch the door notice the drop in door height. Now open about 2 inches and hold the bottom edge of the door at the striker post, pull up gently.... You probably will have a pretty good bit of play in the door. If so you need new pins and bushings.
Jbo
    Kirk Belch
    Kirk Belch
  • Who's Online   3 Members, 1 Anonymous, 1,215 Guests (See full list)
