275/70/18s On Stock 18s
Will 275/70 tires fit on oem 18" wheels? The wheels are off a 2007 Yukon Denali, and Im pretty sure they are 8" wide. I'm almost positive the wheels are wide enough but I wanted to make sure. Thanks in advance.
I have 275/70's on my 18 OEM wheels. Mine is a 08 Chevy Silverado.
No issues. No rubbing; I have a 2" level right now.
I only have 1,000 miles on them so they don't have any signs of wear.
Any pictures???
I'm also considering this wheel but have never seen it on a nnbs
what did you have done to the truck at that point to accomidate those tires?
Had a Skyjacker 2" Level Kit on it with the 275/70's.
sorry I just saw that you had a 2" leveling kit. I'm planning on the rcx 5" lift, so maybe I should get something taller?
There are a lot of more knowledgeable people on this board than me so you might want to check with someone more knowing :rollin: but if you want to run a 33" tire with the 5" lift I would definitely get a wider tire than the 275/70.
Check around on the board I believe I saw some others with the 5" Lift and see what they're running.
  • 4 months later...
I have been thinking about getting this same size tire when I do a zone 3" body lift with my 2" level. Do you guys think it would look too narrow with that set up? I don't want it to look too tall and not wide enough when looking directly at it from the front or back.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 173 Guests (See full list)
