1.6 rockers?
hi everybody
im building a motor for my blazer and i was looking at roller rockers <harland sharps>
i was wondering if anyones had any experiences with rollers to share?
good?bad?ugly?
also are guide plates nessacery when running 1.6 rockers?
ill be running a comp extreme energy cam /231-2
206i/[email protected]    3432/.453lift
motor will RARELY turn more than 5grand with most friving in the 2500-4000RPM range
thanx scott
Harlan Sharps are good, affordable roller rockers. I've used them in BBC's, SBC's and SBF's before with zero problems.
Guide plates are not absolutely necessary when running 1.6 rockers, but you'll have to properly modify the cylinder heads so the pushrods do not bind. Comp Cams makes a tool part # 4710 that will allow you to lengthen the pushrod slot in the head.
cool thanx
this sound like a decent combo for a full size blazer?
400 small-block
ported stock heads
preiviously mentioned cam and rockers
holley dual-plane
750 holley vac 2ndary
turbo 350 stock gears and 33"
Guide plates also align the pushrod side to side.  If the rocker arms are not self-aligning, you will need guide plates.
Mark, that's not the case here. The side to side alignment is done by a slot machined into the cylinder head.
Self aligning rockers are only necessary on '93 and newer LT1, LT4, and Vortec OEM heads.
im NOT running vortecs or any newer style head..........
just stock 70s smog heads
ill let everybody know 100% for sure on this as i sent an email to comp cams
as soon as i hear back from them ill post it
later scott
i heard back from comp cams
if u use the louis tool to elongenate the push rod slots in the head
u DO NOT have to use guide plates or anything else on older style heads
just bolt on the regular 1.6s check ur PtoV clearence
and go smoke the tires
later scott
While you're checking piston to valve clearance, check for spring bind, and also check for retainer to valve guide clearance.
i knew that but thanx
if i know me ill probably double check everything about a thousand times when this thing is going together
what kind of specs am i looking for on retainer to valve guide clearance????
im planning on running the springs that comp recommended for my cam
yes they do know im planning on usings 1.6 rockers
later scott
