First snow in AV
pacodiablo
Yep,.. first snow in Michigan, and my subdivision is snow covered and slippery. I go around a corner, hug the outside of the turn cause an oncoming car is loosing it,.. into MY LANE.
And its too late,.. mailbox at 2:00...
Clip the box with the mirror, and BAMB into the rear quarter panel. :D
Look at the truck.. and well I will ALWAYS get plastic cladding!!!
Not a nick or scratch in the truck,.. just a mailbox at a 45 degree angle! :D
And oh yea,.. the Mickey Thompson tires came off as soon as I got home. Not too good in the snow.
Sorry to here about your "Too Close Encounter".  Big tires and snowy roads don't mix...  Glad the only damage was the mirror.
For as much of an eye sore that cladding is, I'd say it's the best thing chevy has done since they aren't putting in fiberglass panels like saturn.  But, it protects the side of the trucks great from what I've heard and unless a semi hits you w/ his door I doubt you'll be complaining about door dings.
"Av - 1, Mailbox - 0.  Details at 11:00."
Our sub's snow service had the streets salted so quickly that it's only been wet here.  I did go about 140 miles today on freeways and country roads in MI.  Some of the east-west roads were a bit slick, but I never lost traction.
So BBA, do the stock tires and rims go back on?
Stock tires / rims went on right after the little incident :angry:
Dang mailbox shouldn't have been there is the first place.   :D
I also have a winning record against mailboxes.  Last year I sent ours through the snowblower and into the neighbors field.  I've also taken off the neighbors with the field cultivator when a bimbo forced me over into it.
Mailboxes are weak!!!  Show no fear against them, as they are easiliy conquered!   :D
Now I would have paid to see that!  ROTFLMAO!  I've got to say that I have a pretty good record with mailboxes, haven't even come close to hitting one yet.  Probably just cursed myself saying that though.
My thing seems to be hitting hidden metal bars with mowers.  Done that twice last year.   :notice:
Yep, dang dual hub on the 7220 ripped it off the post when I moved ahead.  I put the tractor in reverse and started backing up for another pass.  Right when the blower caught it is when I saw it, too late.  It didn't go up through the chute, but that auger caught it and sent it right across the road.  Thank God no cars were coming because it was like it had been shot out of a cannon.
OH what stories us plow boys could tell from the seats of our tractors.  I caught a mail box between the duals on our John Deere once could hear it go clang and by the time I could look for the noise it was already out of sight and then it would go clang again took about 5 minutes for it to get knocked out from between the tires.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 440 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
