I am about to install dual exhaust on my truck 6.0 (lq4 ) and have decided on magnaflow mufflers. The local exhaust shop is telling me I will get more power if I go 3 inch instead of 2.5, which makes sense at wot but will be bad for normal driving conditions?? It seems all the exhaust systems you can buy are all 2.5, that appears to be the safe route to go just looking for opinions. Thanks for all the help in advance
If you're going true dual, two 2.5 in. pipes will be PLENTY sufficient. :thumbs: You don't need two 3in. pipes, it's not a diesel. You go with two 3in. pipes and it will lose power, because of the slow speeds of the exhaust going through the pipes, you want the exhaust to go at reasonable speed so it will pull more air into the engine. This is some type of principle, but I can't remember the name of it.
"Some type of principle"... What are you talking about? Mass flow makes a difference, not velocity. You are right about two 3" pipes though- This will probably reduce back-pressure too much.
Too big of a pipe will reduce exhaust velocity, thus not having enough suction pulling air into the engine. "venturi principle" talks about how fluids and gases flow through pipes. It states that the pipe should only be big enough to just avoid restriction.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,094 Guests (See full list)
