Knock Sensor Resistance
ken1mod
Gentlemen,
Does anyone know the correct resistance for the knock sensors on a '99 silverado 5.3 liter? I want to make sure they are bad before replacing.
Thank You!!
Ken
With the engine off, around 200 ohms to ground, each. (The two pins in the plug should be separately tested to ground.)
Sir,
Thank you for the reply but my knock sensors only have 1 wire each.
Ken
Sir,
Ken
Yeah, I know but they go to a plug that has both wires in it, that runs on the back driver's side of the intake.
According to GM....93-107K ohms
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
