Would you like a GM-Trucks.com Car Insulated Mug?
Zane
Hi Guys and Gals!  If we can get 25 people to confirm to this, its a go!
Just sign-in here, and let me know.  When we get 25 people, we will do a pre-order, and after all the orders are paid for we will have the product in about 2 weeks.
These are computer generated images, and not a final product. Pricing would be in the $20 range.
I have been thinking a GM-Trucks.com Liceanse plate would be cool!! Its defintitley nice to see all of this merchandise coming out, mugs and hats and stuff!!!!!
I think we are in the possition that we can get almost anything made that people want, provided that we have enough people to buy it.  :)
How about some huggies?  Not the 1/2 inch foam quick-stop kind, but some of the collapsible kind that will fit in your pocket.
that is also a possibility, although, we would have to buy at least 250 of those. And, right now we don't have the money to front the buying of anything we won't be able to "sell" right away.
I'll make up a better logo for the mug above...
I could really use one of those nice mugs for coffee, or whatever else.... :flag:  :lol: and since I am too lazy to go buy myself one I think it would save me a bunch of time vaccuming the broken mugs out of my truck.  I'll definitely get one of 'em!
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
