Build Sheet Request
Go to the dealer and talk to the service department. They will gladly give it to you. Offer to pay for the print out too.
That Is one nice looking ride you got there. I found those same tail lights and the website said they only fit on the sierra 1500, is that true?
Thanks.. I am not sure if they fit the 2500 HD's or not. I thought they had the same bed on the 1500 as the 2500hd but i could be mistaken.
Last I checked they all use the same tail lights, 1500 all the way up to 3500HD.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
