Missing 6.0
hi guy's just posing a question for ant one knowledgeable on the 6.0 ,i have a 2001 2500hd and it started missing in gear at a stop.then as you take off . it only has 45037.0 miles on it ,i changed the plugs it helped .now it only misses when it is warmed up ,not to bad .the wires look ok i will check it with a scanner later to see if it has set any codes.going down the road warm or cold run's like a raped ape don't know what to look at next .any help would be appreciated .
i am running some injector cleaner through a tank of gas now i will try the easey way first
a good TB and injector cleaning may help..
good luck
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 643 Guests (See full list)
