Cab Mount Q
I bought my first GMT800 this week (see sig) and the first thing I did was remove the nerf bars. While I was doing that, I noticed that the bolts in the rear mounts have a large flat washer under them, but the middle and front mount assemblies do not include these washers. Is this the way GM intended it or did the nerf bar installer forget to replace the front & middle pairs? Thanks!
Just a guess, but he probably put them in there to alleviate a creaking noise sometimes happening when the bar mount contacted the body mount pocket. If it were me, I'd add washers on the other bolts and torque them all to 75 lb/ft.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
