Loud Engine Noise
2004 GMC Sierra Crew Cab; 127k miles.
When I'm starting out gaining speed, the engine or transmission is making a loud vrrrrrrrrrrrrrmmmmm. It quits once I get to about 40 mph, but everytime I start out going, I can hear. It makes me feel like I'm driving an older model truck. I'm just curious if its normal, or does something need to be serviced. I've never done any major service on the engine or the transmission.
Thanks in advance.
Thanks in advance.
U joint?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
