Gibson Headers And Borla Catback
I recently installed a Borla cat back on my 4.8L 04 Sierra. I was pleased with the set up when I unpacked it from the boxes, but the warm fuzzy feeling soon slipped away when I began the install.
The pipes existing the muffler were different lengths and the pipes did not line up no matter what I tried, I began installing the system loosely and tightened the set up from the cats back, nothing worked. The passenger side pipe touches the dust shield on the shock and I had to bend the pipes and trim a little off the passenger side pipe to have my tips the same distance back from the bumper. I thought the few extra bucks I payed for the Borla would have saved me the grief. I guess the extra cash was for the 304ss the system is made from. Any way enough complaining.
My question is regarding headers, I have the inner most exhaust manifold bolt heads missing on A and B cylinder banks, so I have to get it fixed. The manifolds are almost surely warped, so a set of shorty headers are my next project. I have looked at Gibson and seem to think they are work the money, but will I have similar problems with fit up as I did with the C back? Looking for some input on Gibson or any other brand. I prefer to do my own work so any tips on removing badly rusted bolts from an Aluminum head would also be welcomed. I know I should be looking at long tubes but, I'm a little lazy just what a simple bolt on.
i have edelbrock shortys and their ok. like i noticed some difference in power and it DOES make the truck abit louder. I didnt have any problems installing them. Just dont cheap out on gaskets. I use fel-pro gaskets on my truck and i got no complaints. Just watch the donut gaskets. I seem to burn them more but then again im running edelbrock. Not always a good choice with them haha. But install wise shit takes me not even 20min to install them. Getting the old manifold off can be a bastard. Try not to damage the down pipe while getting them off
also a penetrating oil would work thats how i got mine off. just soak the shit outta them and let them sit for some bit and then slowly turn the bolts out. dont force anything or you will break
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
