Fill Up Problems
usethegift
2004 2500 hd gas 6.0 . the bed was off this truck a few weeks ago at a body shop. d i c display start to say tighten fuel cap. now only when i refuel the truck it is very hard to start. took it to auto zone they read the code and suggested that i change the gas cap and purge valve. did that same problem . any ideas? thanks
my advise is to take it back to the body shop and tell them they *&^%$$ed up your truck and want it fixed ASAP,the vent hose is kinked or something
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
