Fuel Offroad Gauge Rims
pharmboy2010
Does anyone know if the Fuel Gauge all come with the bigger center cap like pictured on their website or just the 8 lug??? The pic of the Sierra they have on the website has a smaller center cap (more blank machined space around center). I definitely like the look of the bigger center cap.
Thanks
good to see another person here is trying to run Fuel wheels. Check my album, but yes the 6 lugs come with the huge center cap. I am running them right now on my truck. Just note though, better buy a allen wrench to have with your jack and stuff so when you have to change the tires you can remove the cap. They are bolted to the wheel, so they require an allen wrench to unscrew one the chrome nuts in order to access your lug nuts
here is a picture of mine:
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
