Metal Bed Raiol Caps
I am looking for a good set of stainless steel bed rail caps with a smooth polished surface, to be mounted with 3M double sided tape. I looked at Dee Zee and Putco. DeeZee caps require drilling and bolt installation, Putco caps do not. Dee Zee caps are made of 16 gauge steel, while there is no info on Putco ones. Anybody has a set of these? Any onther brands out there of sufficient thickness? Smooth polished aluminum ones would be acceptable as well.
I have the Dee Zee diamond plated caps on my truck. It came with the double sided tape already on and it had bolts to install in the lip of the bed. I did not install the bolts or use the tape. I did drill a hole in the top of the cap and installed tie downs in the stake pockets. This keeps the caps tight on the bed and provides extra tie locations. You can also remove the caps easily to clean under them from time to time. Hope this helps.
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
