P0060 Code. Please Help Me.
I am getting a reading for Bank 2 Sensor 2 heater resistance code P0060. I have replaced all 4 of my O2 sensors, and just replaced the fuses for both banks today and my check engine is still on. What can I do to fix this? Please help me. :drool::drool:
Stupid question- did you clear the code after you swapped out the sensors? Try leaving your battery unplugged for 15 mins.
Yeah, I cleared the code and it was off for 2 days. The check engine light came on today right as I started it up to go to work.
Sometimes new O2 sensors, in particular heated O2 sensors can go bad quickly out of the box. Is Bank 2 sensor 2 behind the CAT or in front of it? Most sensors behind the CAT are not heated I believe. Sometimes a bad Cat Converter can foul or overheat the O2 sensors.
If I remember correctly Bank 2 side 2 is behind the cat. I have brand new cats on my truck so I know that they arnt bad.
