K&n Vs. Volant
I was going to go with the Volant oil less CAI but the K&N had so many good reviews.
K&N. Just don't over oil it.
I have the volant on my 09 5.3. I am pleased with it. Sounds good when you get on it. Not too much of a diff in power id say. Like they said get a tune if you want to feel something. Im finally gettin BB tuned in Nov :thumbs:
go with a Volant with a Dry Filter, they have a sealed enclosure. With the K&N filter the oil ends up on the MAF sensor and you have to clean regularly
yes if you go with volant get the non oiled filter. this filter has a 100,000 mile life (i believe) with no oiling or maint.
I've had both. Never had a problem with either. Currently have the Volant non oiled filter. I prefer it because it's maintenance free.
