Horn Question
has anyone else had there horn quit working? The horn works through the remote so it is not the fuse or the relay or is there a seperate relay for the steering wheel button.
  • 1 month later...
I'd say it's the contacts in the steering wheel, hence why I am here searching the forum. Mine still works if I press right on the center of the airbag/horn button, but none of the corners are working.
my horn stopped working a few months and i checked fuses and all that good stuff... they were all good. so i went to pep boys and bought 2 new horns and replaced the 2 stock ones. works like a champ now.
Well, my horn no-op was dirty contacts, the copper strips where the horn ground contacts strike under the air bag in the steering wheel were oxidized and dirty, a little sand cloth and all is well.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
