Honjda ATV 2004 Sneak Preview
TxDoc
http://preview.hondamotorcycles.com/atvs/u...elId=ATPREVHN7G
Here are the specs.
Engine Type 397cc air-cooled OHV dry-sump longitudinally mounted single-cylinder four-stroke
Bore and Stroke 85.0mm x 70.0mm
Carburetion 32.0mm CV
Ignition DC CDI
Starter Electric with auxiliary recoil
Transmission Fully automatic hydromechanical, continuously variable, with electronic controls
Driveline Direct front and rear driveshafts with limited-slip front differential
Front Suspension Independent double-wishbone; 5.9-inch travel
Rear Suspension Swingarm with single shock; 5.9-inch travel
Front Brakes Triple-sealed hydraulic drum
Rear Brake Sealed mechanical drum
Front Tires 24 x 8-12
Rear Tires 24 x 10-11
Length 80.0 inches
Width 43.9 inches
Height 45.2 inches
Wheelbase 49.1 inches
Seat Height 32.4 inches
Ground Clearance 7.2 inches
Turning Radius 10.8 feet
Dry Weight 559.0 pounds
Fuel Capacity 3.8 gallons, including 1.1-gallon reserve
Available Colors Olive, Red, Yellow
Model ID TRX400FA
    btm
    btm
  • Who's Online   6 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
