Ionic Voyager Nerf Step Bars ?
I have a couple of buddys that have these. They like them. Good luck with removing the middle body mounting bolts on your 2010. Both the driver and passenger side mounting bolt nuts were not welded very well on my 2010 and the bolt just spins. Dealer says not in warranty. I say GM lack of quality.
Can you get or do you have a picture of them on your buddys trucks? Am I going to have that same problem on any steps I install with the middle body mounting bolts?
Please see the last reply on my post titled 'Repair Body Mount Bolt on 2010 Silverado'. GM is aware of the problem on 2010 & 2011 Silverado and Sierra full size trucks.
Spiral Gray
It appears these bolt on almost the same way as the GM 6" oval assist steps (part # 20921113). Watching the video it shows them being bolted on the inside of the body frame area, not up in the cab mount area. I purchased a set of the 6" GM ovals from gmpartsdirect for my 2010 Silverado Ext Cab and put them on with the help of a friend. They are very sturdy this way also and appear to bolt on the same way. IMHO, the ovals look better and provide better footing than the round ones. I had the round ones on my 06 GMC Sierra so I can vouch for that. Hope this helps.
I like the look of the ovals and the bigger footing but i dont like the dealer price of around 600. I saw those on ebay for 350 free shipping and they look almost identical but also I know down the road you usually get what you pay for.
The OE GM steps come with the brackets already on the steps. All you have to do is mount them to the inside. Complete in less than 45 minutes. 455 at the place I stated earlier.
Yep :lol:
Sorry, just noticed yours is a GMC Crew Cab. For you, it will be GM PART # 20919889
I have a set of the 5" oval models and so far have been happy with them. Time will tell, only have had them since June or so.
Chris
  • 3 months later...
Sorry to revive an old thread, but I did a lot of thinking about steps for my new truck. I wanted something that bolted to the rockers as I had read, thanks to the forum, about GM's body mount bolts giving problems with nerf installs going to the cab bolts. Also I wanted to avoid any creaking in case something with the cab bolts didn't line up right or was in a bind. I really liked the GM OEM bars but so did GM to the tune of around $500 or better. So I took a chance on these. I actually bought them from Running Board World. But after I ordered I realized the same boards were available from the same people at ebay. Ionic Voyager on Ebay If you order from ebay you can save yourself $20.
I ordered around 6:00 P.M. on Wednesday, and they were delivered by UPS at 12:15 today, Friday. I was surprised that the boards were made in Taiwan and not China. They were well wrapped and arrived in excellent condition. The brackets and hardware came in a separate carton. Everything was packaged REALLY well.
In the crew model, GM has welded a nut to the backside of the rocker for such an installation for the front two brackets, so these bracket installs were VERY easy. The two rear brackets had to be installed by pulling a body plug and inserting a clip. (Exactly like in the ebay video) I have no idea why GM included the mounting hardware for the two forward mounts and not for the two rear??? Once the brackets were up the board install was very easy. Everything was snugged up with 1/2 inch socket and was good to go in a little over an hour. Once you get the understanding of how the install works it goes fast. The directions provided are VERY poor and do not seem vehicle specific, but if you know what you're looking for it isn't bad at all. If anyone is interested just reply or PM, I'll help with whatever questions you have if I can.
After everything was installed I was really surprised how sturdy the boards seem. The brackets seem a little lighter than the OEM ones but I honestly can't tell it by the step into the truck. Everything is super firm with ZERO flex. They feel every bit as firm as the Nasta nerfs I had bolted with the cab bolts on my 2004.
If you're looking for a nice wide step that is modeled (if not identical) to the OEM boards, the Ionic Voyagers are a good bet. I cannot speak to longevity; only time will tell, but day one impressions are a 10 out of 10.
Here's a couple of pix. Sorry about the quality, but I had to take them in the garage as it was dark and snowing outside.
vroten
Nice looking steps
Thanks,
After I installed I went by the local dealer who has a truck with the OEM steps on it. Other than the brackets that I mentioned in the earlier post, they appear identical. The OEM steps seem to have a plastic cover over the brackets where these do not, but I am completely happy. We'll see how they hold up.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 1 Anonymous, 924 Guests (See full list)
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
