2011 Denali 1500
What are my options for this truck body lift? leveling kit? Anyone with any pictures? Would like to use a 20x9 wheel with Cooper LTZ tires. Looking for suggestions
Leveling kits, body lifts, and suspension lifts will all give you more clearance. Which one of these you use really depends on what size tires you wanna run.
Matt
What sive wheels and offset did you use? What size tires? Is there a leveling kit that is better or hopefully le3ss change of vibration
Matt
I'm currently running 305/50/20s on 20x9 +0mm offset wheels with a 3" body lift. My previous setup was 305/55/20 ATZs on 20x9 +18mm offset wheels.
As far as a leveling kit is concerned... it's hit or miss. You can spend $70 on the 2" RC kit and see how that works. If you have vibe issues, you're only out $70+alignment. Then you can try a 1.5" kit.
Another option, which i really like, is the CST coilover kit: http://cgi.ebay.com/ebaymotors/CST-2007-20...sQ5fAccessories
Then you can vary the height to maximize the ride height increase without vibration. When the time comes to replace my coil bodies I may go this route.
If you want to play it safe off the bat, find a 1.5" leveling kit and call it a day. Or just get a 3" body lift :cool:
Matt
If you want to play it safe off the bat, find a 1.5" leveling kit and call it a day. Or just get a 3" body lift :D
i just bought a brand awd 1500 denali, i was planning to buy a rc 2 leveling kit but im not sure anymore what you mean vibration it is from cv joint being too angle or which body lift will you recommend me i dont wanna mess up the truck since its brand spanking new and warranty too
tommy
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 273 Guests (See full list)
