Removing Door Panels And Rear Seat For 09 Sierra
hey guys just wondering if anyone here would have a walk through or a diagram on how to remove rear seats and door panels as i will be installing my stereo system by myself. Local stereo shop charging me alot of money so i figured ill do it myself since i have the tools to do it. thanks !!
I'm pretty sure the seat will just unbolt and you can pull them out. Door panels have 2 screws (10mm socket, IIRC) under the handle (remove the rectangular access panel) used to close the door and 1 screw (also 10mm socket, IIRC) behind the door opening handle (remove the access panel). Using a small screwdriver, pop the catch mechanism on the door lock out and remove the pop-up lock (the catch won't pull completely out; it will just "pop out" a little bit). Using a small pry bar (or trim panel tool), insert between the door frame and door panel and "pop" the trim snaps out, working around the door panel. Once all are popped out, lift up on the door panel and pull back. You should be able to access the speakers without disconnecting the wiring (if it's the same as the front doors, there are 2 "catch arms" on the bottom of the panel and 2 cut-outs in the door frame where you can hang the panel while leaving the wiring all connected.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
