Intakes!
Hey guys!!
i was wondering if any of you are running a k&N intake or something similar on your GMT900's with a body lift???
and is there any difference in mounting one between a 2008 and a 2009 + year model truck??
my parts guy i deal with has been stuck with an K&N intake and is willing to take a hit on it to get rid of it?
Thanks
Tim
I believe 08-09 part numbers change bacause in 09 they changed the location of the MAF sensor... At least I know that Volant and GMPP 08-09 differ and would assume K&N is the same way. Go K&N's web site and see if the part number changes between the years and you will know for sure.
Yep,'07-'08 and '09-'11 are two different designs for this very reason,the MAF sensor mounts differently.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
