Power Steering
rcw8947
I have a 2004 GMC sierra 1500 4x4. My problem was i had no power steering when i turn to the right. Turning to the left was fine. I was told it was the power steering box. I ordered one, which was remanufactured, and after installing it i do not have power steering when i turn to the left, turning to the right is fine just the opposite of the original one. I flushed the lines and pump and refilled with new fluid. Is there something i am missing or did i get a bad box. Any help will be much appreciater.
  • 1 month later...
Replace the steering gear again.
+1 You got a bad box. This is a symptom of a leaking spool valve inside the box. It's the only thing that can cause it and it can cause the problem in either direction.
