Rear End Codemy Glove Box Codes Have No G Codes For The Axle?where Els
If the sticker is still there in the glovebox, the rear end code is on it. If it's gone the VIN should help. Worst case... pull the cover and count teeth!
You can also count it. You will need a helper. Raise one tire off the ground. Put a chalk mark on the drive line and a mark on the raised tire. Have your helper turn the tire 20 times, while you count how many times the drive line turns. 34 and a little more turns means you have a 3.42 axle. 37 and a little means 3.73. 41 turns even means 4.10.
Thanks it says GU5. I have the 3.23 ratio.What does the LY2 cylinder Deactivation code mean?
it means you have afm
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 699 Guests (See full list)
