Radio Illumination
I have a 2000 Sierra. The radio has no illumination of the controls/buttons. Has anyone had experience, and can offer advice, on repairing the problem? Also, where is the tow/haul light located? (yes- the tow/haul works)
Thanks for your input !!
I havent taken it apart yet to replace lamps, but here's a tip. If you DO replace the bulbs replace ALL of them. One bulb went out on mine, and then in about a year several more have died, and im sure whats left will die soon
Do you know the bulb part# ? Thanks!!
not sure of the part number but they are 13.5V bi-pin soldered bulbs... i think they are 50mA.. ill do a little research and let you know if i find anything
It is Done!! :nopity:
I bought bulbs and soldered them in. Replaced 10 bulbs in all. They weren't black, just broken fillaments. Maybe previous owner did alot of off-roading lol. The repair was fairly easy. It was the first time I used desoldering braid, stuff works really good.
Thanks to everyone for all your input.
I am pulling cluster to check out tow/haul light now
I replaced the TOW/HAUL light aswell, turns out it is an L.E.D., mine was broken in half. Its a white light now, not sure what it is supposed to be. I also found that a previous owner put black tape over the ABS light, (so begins the next chapter)
I noticed the truck has a 4X4 light in the upper left corner of the cluster, that doesn't work, but L.E.D. is good. Any thoughts out there?
As for the HVAC controls, I am not sure what is supposed to illuminate. Does the recirc, and outside air button(s) have back light? or only an indicator light?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
