Can Someone Pull A Build Sheet Using The Vin?
I'm going to look at at Yukon XL tomorrow and I'd like to see a build sheet before I go.
VIN is 1GKGC26K87R408203
Vehicle: YUKON XL/ESCALADE ESV 3/4 TON
Year: 2007
Build Date: 2007-05-15
Found 6,828 vehicles matching your year and model in our database.
RPODescriptionMatchesUD7SENSOR INDICATOR NEAR OBSTACLE DETECTION/REAR PARKING ASSIST RR PARKING ASSIST/OBSTACLE DETECTION SENSOR(UD7)
5,934UE1COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
3,723UG1OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
3,381UJ6INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)
6,828UK3ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
6,618UK6RADIO CONTROL REAR SEAT & EARPHONE JACKS RR ST AUDIO(UK6)
3,990UQASPEAKER SYSTEM PREMIUM PERFORMANCE ENHANCED AUDIO PREMIUM SPKR SYSTEM(UQA)
3,408UVARADIO AM/FM STEREO, SEEK/SCAN, AUTO TONE, CD, CD-R MP3, DVD, CLOCK, ETR, RDS STEREO W/CD MP3 & DVD(UVA)
1,173U2KDIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
3,264U42ENTERTAINMENT SYSTEM REAR SEAT,SINGLE DISPLAY,REM CONTROL W/HEADPHONE ENTERTAINMENT SYS(U42)
2,199U84ANTENNA BODY SIDE WINDOW, RADIO BODY SIDE WINDOW RADIO ANT(U84)
6,828VFFVIDEO FORMAT REGION 1, NTSC REGION 1 VIDEO FORMAT(VFF)
1,971VGDFASCIA FRT, CUSTOM, BODY COLOR BODY COLOR FRT FASCIA(VGD)
6,828VGEFASCIA RR, CUSTOM, BODY COLOR BODY COLOR RR FASCIA(VGE)
6,828VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
3,360VR4TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
6,828VXSUnk.6,828V1KBAR LUGGAGE CARRIER,CENTER CROSS LUGGAGE CARRIER(V1K)
5,943V54CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
6,738V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
4,008V76HOOK,FRONT TOW FRT TOW HOOK(V76)
HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
6,828YD3AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
6,828YD5SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
6,828YD6SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
6,828YE9CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
6,828ZIZTIRE SPARE LT245/75R16/E BW TL ALS 120Q SPARE TIRE(ZIZ)
3,903ZY1COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
6,807Z85CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85)
6,798Z88GMC TRUCK G M C(Z88)
6,7981SZPACKAGE OPTION- (1SZ)
3,73819IINTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
INTERIOR TRIM,EBONY (19I)
1,668193TRIM COMBINATION,BLACK LEATHER (193)
1,0474SBPACKAGE SLT OPTION 2 SLT 2 OPTION PKG(4SB)
2,55959UEXTERIOR COLOR,PRIMARY (59U)
EXTERIOR COLOR,PRIMARY,FINE SILVER BIRCH MET (59U)
1,3086GKSPRING COMPTR SELECT FRT LH SUSP(6GK)
6,7987GKSPRING COMPTR SELECT FRT RH SUSP(7GK)
6,798AG1ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
6,819AG2ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
3,036AJ1GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
3,954AL0SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
6,828AL4SEAT,REAR,BUCKET RR BKT ST(AL4)
1,653AN3SEAT FRT, INDIVIDUAL/NON-BKT INDIVIDUAL FRT SEAT(AN3)
3,036AP3LOCK CONTROL REMOTE, KEYLESS ENTRY, START REMOTE KEYLESS ENTRY & ENGINE START(AP3)
6,081ARLPLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
6,828ARSADJUSTER RR REAR SEAT, POWER, STOWABLE PWR STOWABLE RR ST ADJ(ARS)
1,869ASFRESTRAINT ROOF SIDE, LH & RH, INFLATABLE LH & RH ROOF INFLATABLE RESTRAINT(ASF)
SEAT DRIVER,AIR,LOW BACK,VINYL,BOSTROM 910 DRVR LOW BACK AIR SEAT(ASF)
3,789AS3SEAT,#2 REAR UTILITY REAR SEAT #2(AS3)
SEAT,REAR UTILITY R/SEAT(AS3)
5,631AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
6,828AXPVIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
6,828A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
6,828BVESTEPS RUNNINGBOARD, SIDE RUNNINGBOARD SIDE STEPS(BVE)
6,825B30CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
6,645B39CARPET,LOAD FLOOR LOAD FLR CPT(B39)
5,823B58COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT CPT INS FLR MATS(B58)
6,645B85ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85)
6,624CE1WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE W/S WPR,PULSE MOISTURE SENSITIVE(CE1)
1,680CF5ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
2,277CJ2HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
6,129C25WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
6,828C36HEATER,AUXILIARY AUX HTR,RR(C36)
6,828C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
6,828C6PGVW RATING 8, 600 LBS/3, 900 KG 8600 LB/3900 KG GVWR(C6P)
6,828C69AIR CONDITIONER,RR AUX RR AUX A/C(C69)
6,828DF5MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY I/S REARVIEW MIR W/COMPASS(DF5)
6,828DH6MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
6,828DK8CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
6,828DPNMIRROR O/S LH & RH, WIDE LOAD, VERTICAL GLASS, MAN EXTENDING MAN FOLDING, HEATED, TURN SIG IND, REMOTE CO WIDE LOAD MAN EXTENDING/MAN FOLD O/S MIR(DPN)
336D07CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM) CUSTOM F/CMPT FLR CNSL(D07)
3,996E2CUnk.4,833E52BODY EQUIPTMENT ONE PIECE LIFT GATE WITH LIFT GLASS BOD LIFT GATE W/GLASS(E52)
6,828E61LIFTGATE, POWER PWR LIFTGATE(E61)
2,538FE9FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
2,844FT2ARM TORS BAR SPRING ADJ (FT2) ARM LH TORS BAR SPR ADJ(FT2)
6,828FT3ARM TORS BAR SPRING ADJ (FT3) ARM RH TORS BAR SPR ADJ(FT3)
6,828GT4AXLE,REAR,3.73 RATIO 3.73R(GT4)
5,178G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
6,795JF4PEDALS ADJUSTABLE, POWER PWR ADJ PEDALS(JF4)
5,934JH6BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS BRK HYD PWR DISC(JH6)
6,828KA6HEATER,RR SEAT REAR SEAT HEATER(KA6)
1,530KC4COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
6,828KG3GENERATOR 145 AMP 145 AMP(KG3)
3,876KNPCOOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
6,828KUPTHROTTLE CONTROL VARIABLE SPEED (ELECTRONIC) ELECTRONIC THROTTLE CONTROL(KUP)
6,828K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
6,828LY6ENGINE GAS, 8 CYL, 6.0L, SFI, IRON, GM 6.0-K/N(LY6)
6,828MT1TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E) 4-SPD A/TRANS(MT1)
6,828NP5STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
6,828NT8EMISSION SYSTEM FEDERAL, TIER 2 A TIER 2 A FED EMIS(NT8)
2,844NZ3WHEEL SPARE FULL SIZE, 16" STEEL FULL SIZE SPARE WHL(NZ3)
6,828PY0WHEEL,16 X 6.5,ALUMINUM ALUM WHL(PY0)
6,642QIWTIRE ALL LT245/75R16/E BL R/PE ST TL OOR TIRE(QIW)
TIRE ALL LT245/75R16/E BW R/PE ST TL OOR 120Q TIRE(QIW)
1,377RYJCOVERING,CARGO AREA,RETRACTABLE RETRACTABLE CARGO CVR(RYJ)
4,647R6KUnk.5,142R6PUnk.3,693R9LUnk.309R9NUnk.3,750R9XUnk.1,527R9ZUnk.2,451SAFLO
CK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
6,828SLLSOLD ORDERS SOLD ORDER(SLL)
2,310SLTEQUIPMENT CHEVROLET 'LT' OR GMC 'SLT' SALES PKG 'LT'/'SLT' EQUIPMENT/SALES PKG(SLT)
3,321TFEUnk.3,240TL1GRILLE,SPECIAL SPECIAL GRL(TL1)
6,828T74HEADLAMPS CONTROL AUTOMATIC, DELAY AUTO HLDP(T74)
4,008T96LAMP,FRONT FOG FRT FOG LP(T96)
6,471
Thanks guys, I appreciate it. I didn't realize there were websites out there where you could run VIN's for free.
