Quick Question
becker87
What magazine, or tester still does 1/8th mile times? I need to find one for my truck, I have tried looking all over and can not find one.
Any help would be great!!!
Thanks
Mitch
Ok how about this one.
What is the calculations for taking 1/4 mile MPH times to 1/8 mile times. I have found a calculator for just this on the net but i need the calculations they used which they did not give me.
Not sure of many magazine test that show 1/8 mile times. When you run the 1/4 your 1/8th mile time will show up on the slip. I have no idea what your truck runs in the 1/4 but as a guess a vehicle that runs low 15's to high 14's in the 1/4 is usually looking at somewhere in the low 10 second to high 9 second 1/8th mile time. Of course thats all variable upon 60' times, etc..
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 523 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
