New from Indiana
samckitt
Hi gang.  I'm new to the list & thought I would introduce myself.  My name is Scot & I am about to order a K1500HD LT Silverado.  My other project car is an 86 Monte SS with a 95 LT1 & T56 6speed trans.  That thing is fun to drive.
I also have a question about which rear gear to order.  Look for that post seperately.
Thanks,
Scot
Welcome.  Keep the questions coming, we are glad to answer them.  Post some pics of the new truck when you get them and you Monte too... :thumb:
I have a website with info on the Monte.  You can get to it here:  www.home.earthlink.net/~smckitt
I can't decide which truck to get now.  I am concerned that the 6.0L is going to suck (no pun intended) in gas mileage.  But because of a new addition to the family the first of September I feel that I should buy something with 4 doors, full size doors.  So my choices are the 1500HD or an Avalanche.  I AM NOT BUYING A MINI VAN!  I refuse.  What are everyones thoughts of the look of the 1500HD compared to the Avalanche?
Thanks,
Scot
    C. Hart
    C. Hart
  • Who's Online   5 Members, 1 Anonymous, 605 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
