Cab Lights Power
BrucesEx
So I tried to search for my answer but go no where other then thousand of install topics for cab lights/roof markers/clearance lights.
My problem is on a 2005 I've lost my cab lights, Bulbs are fine, harness from passenger side to lights is fine all of that I tested.
I can't see any blown fuses underhood or driver side door. All other park lights work. What I am looking for is if someone can tell me where the wire runs to from the passenger side panel. Does it go back to under the hood? or headlight switch? Somewhere behind the passenger side panel I have lost power. Is there a fuse just for cab lights?
I'd like to find the broken wire or bad connection, before I give up and just run a new power wire.
Should be a harness that plugs in under the drivers side dash, you'll see a bunch of harness that plug in there. It should be one of those.
I know it's like that on the GMT-900's, not sure about the 800's though.
There most likely isn't a specific fuse for them though.
Thanks I actually found my problem after posting this. It wasn't a blown fuse but actually the fuse wasn't making contact on the unpowered side in it's holder.
It actually seems to be on the same fuse for the trailer park lights, from a few diagrams I found. forget what the label was on the underhood fuse box.
