2000 Gmc Sierra
i have a 2000 gmc sierra 2500 with 6.0l it has a 6 inch suspension lift i recently blew front drive shaft out of it it was in pieces not sure what type of suspension lift but i am not sure if it was stock drive shaft of when it is lifted or is it after market any help would be great thanks
Unless your truck has a straight front axle that's been put in it. That's the stock driveshaft. Because the front diff does not move with the lift.
ok thanks but dosnt the rest of truck lift like transfer case i know it had a dual cardigan drive shaft looked like stock one
yes, the truck lifts, but the location of the t-case relative to the front diff stays the same or changes minimally. Not enough to need a aftermarket shaft though. Now the cv axles are a different story.
well thank u very much for the info now i can go order one thunk u they were telling me with lift need different front drive shaft
Who is they?
parts dealer also telling me that stock shaft is not dual cardigan joint drive shaft should it have a dual cardigan joint drive shaft for stock or is that after market
Stock on these trucks are not dual cardigan, the cardigan is in the transfer case.
so do i need to get a dual cardigan drive shaft
6" lifted IFS trucks need a custom front driveshaft, with a dual cv joint, to avoid driveline vibrations if 4WD is used on the road (snowy conditions, etc.) It's stated right in most every lift manufactures lift kit instructions. The diff is dropped on most IFS lifts to keep front cv axle angles in check.
I am not 100% about this. But on certain lifts if you have auto 4X4 they recommend a different driveshaft. This is for certain years too.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
