Blazin Electrical Issues
mychevyvan
:thumbs: to all! Please give me some direction to resolve these issues? The worst is the 4 wheel drive buttons are not working! I replaced a heater core in this truck and have found these electrical issues after the fact. I did not drive the vehicle before buying it (project truck) so I do not know if these issues were pre-existing or not. I could have missed a reconnect of one bundle of wires if it sounds like any of these wires would be bunched together. Any thoughts? I checked the fuses and they seem to be all good... Thanks for any help!
We've got snow on the ground and you all know how well a 4X4 works without 2?! Any takers on this one? I can usually fix it but diagnosing is my weakness! Please throw me any ideas you may have... Thanks again!
Sorry I'm not being patient enough but I noticed tonight driving home the 4X button letters all illuminate so I assume there is power to the dash buttons?! :lol:
:cheers: A second look at the fuses resulted in finding the 10 amp fuse blown for the courtesy lamps... a quick replacement and BAM an immediately blown replacement fuse! So what is the next step to trace down the cause of this short???
  • 2 months later...
I have a 98 blazer as well. ~7 years ago had some funny things going on with the dome light & dash lights. Found the battery had a small acid leak at the side pole connector. After removing the battery, flushing the area with baking soda/water mixture & putting in a new battery, the problems went away and the dome light started working normally again. No other changes made.
I had a 97 blazer that had a short and the dome lights wouldn't work right and kept blowing fuses. Ended up being the wiring harness in the seat was shorting out on the seat frame rail. Found it by accident when I was driving because I was moving my leg back and forth and it was making the lights turn on and off. Not gonna lie though, it was a pain to get to.
