350 Tbi
hey guyz,
My truck is a 95 2500ld 4x4 with the 350tbi/4l60e combo. she only has 144k on her but i notice that she burns alot of oil. since i have has it, i have put 3bottles of oil(without changing the oil since i got it). is this a common problem with the 350s? my dad had a vortec 350 and never had this problem. other than that, she is fine. is there anything i can do to make this 350 last longer(2years) until i swap a vortec 383 in it?
Thanks
Kirk
Hey Kirk,
My '94 GMC 2500 4x4 did the same thing at around 180K. I tried the Slick 50 High Milage Treatment. The truck smoked like a mesquito control wagon for a couple of weeks, then settled down and uses hardly any oil since then. That was about 3 years ago. You could try that...
Good Luck
Jim B.
my 99 3500 with a vortec 350 would burn about 3 quarts every 3500-4000 miles. it all started around 120k got rid of truck around 153k. it something that just happens with these engines around that amount of miles. many of them just need a nice rebuild after 150k or so.
The TBI K engines were known for valve guide and seal issues. Have a leak down test done on it to confirm
what the piston ring seal is like and go from there. Seals can be done fairly simply in the truck, with the right
tools. Guides? Off with the heads. :uhoh:
+1
I've done this on many a 350
I have had many 350 s and never an oil problem, 1 qt added at 3000 miles on 6000 mile change intervals. Heavy work engines. They burn lots of oil instantly when overheated, stuck oil rings on rebuild.
ken
I see a lot of it with the TBI 350's. its just simply that they get warn out, be it a seal, mine is from a bearing, whatever, I dunno. Seems like probably a seal in your case
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 457 Guests (See full list)
