2003 Gmc 2500 Xfer Case Grenaded
Havasubum
My son discovered a large amount of trans fluid under his 2003 GMC 2500 Duramax 4x4 on Monday morning. The truck is mostly street driven, has towed a 5th wheel trailer for about 10,000 miles (2wd only), a boat occasionally only to launch it, and has 65,000 miles on it. The dealer discovered a hole in the side of the transfer case caused by gears failing and striking the case. The dealer stated he has seen this before.
My son is a stickler for maintaining his vehicles and changes fluids frequently. He doesn't abuse his stuff. Has anyone else heard of this happening? I can't believe it killed itself with so few miles on it.
Thanks
no probs
you can replace the rear half or have the garage/dealer have it welded locally ,i sent a bunch out for repair and it worked but had to sand the rear outside diameter of the rear output bearing for the rear case to slide over it , the heat of welding must of caused it .
way cheaper than a new rear case half !
a couple of options for you to consider
Rob
Thanks again for the help Rob. I think my son is going to have the dealer repair it.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
