Recall Check
I've checked NHTSA's website, and the ONLY Recalls for for Chevrolet for the 2009 MY are for the Cobalt, Malibu, and Traverse. so your Tahoe is Clean, in More Ways than One! and if you do not believe me, you can go to your Local Dealer, and have them run a Recall Check.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
