New drug warning!
Frank S
DRUG WARNING
Police warn all clubbers, partygoers, and unsuspecting bar regulars to be alert and stay cautious when offered a drink from any woman.
A new date rape drug on the market called "beer" is used by many females to target unsuspecting men.
The drug is generally found in liquid form and is now available almost anywhere. It comes in bottles, cans, from taps and in large "kegs."
"Beer" is used by female sexual predators at parties and bars to persuade their male victims to go home and have sex with them. Typically, a woman needs only to persuade a guy to consume a few units of "beer" and then simply ask him home for no strings attached sex. Men are rendered helpless against this approach.
After several "beers" men will often succumb to desires to perform sexual acts on horrific looking women to whom they would never normally be attracted. After drinking "beer," men often awaken with only hazy memories of exactly what happened to them the night before, often with just a vague feeling that something bad occurred.
At other times these unfortunate men are swindled out of their life's savings in a familiar scam known as "a relationship." It has been reported that in extreme cases, the female may even be shrewd enough to entrap the unsuspecting male into a longer term form of servitude and punishment referred to as "marriage."
Apparently, men are much more susceptible to this scam after "beer" is administered and sex is offered by the predatory female.
Please! Forward this warning to every male youknow. However, if you fall victim to this insidious "beer" and the predatory women administering it, there are male support groups with venues in every town where you can discuss the details of your shocking encounter in an open and frank manner with similarly affected, like-minded guys.
  • 3 weeks later...
in your best polka vioce, every body sing:
In heaven there is no beer, that's why I drink it here, and when I'm gone from here, all my friends will be drinking all my beer....
:cheers:
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.    A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
    • You didn't say what year it is. I have a '17 5.3 6l80e & used the Range AFM delete for a while to stay in V8 mode. Then I got a local tuner to preform a HPTune on my 6l80e & love it. He did a AFM delete, torque matching between engine & transmission, removed converter slip and mild engine tune that helps the transmission. Gears shift better, at specific speeds, no hunting for gear, no 2 gear down shifts, no spark plug miss feel. Drives like a different truck. I highly recommend it.
    • I know this old thread but I just replaced the left side engine mount on my 2018 5.3 2wd and it was a pain. A quick search showed that it was probably going to cost around $600 to $900 to get it replaced. I researched how to replace it and decided to do it myself being that I'm retired and have the time and tools. What should have taken a day took me 4 days plus a couple trips to my chiropractor and some blood. Why a mount failed at 150k miles is beyond me but such is life.   Peace
