Pricing: 1500HD vs. 2500 & 2500HD
I was just checking out the '03's on the Chevrolet website and noticed the pricing of certain models:
1500HD - 2WD starting at $30,422  4x4 starting at $33,860
2500 - 2WD starting at $23,627  4x4 Ext. Cab starting at $29,822
2500HD - 2WD starting at $23,877  2WD Ext. Cab starting at $26,257  4x4 starting at $26,722
Why is the 1500HD considerably higher than its comparable 2500 and 2500HD counterpart?  ???
Or even the 3500?
3500 - 2WD Ext. Cab starting at $27,814  4x4 shown starting at $28,222
I may be wrong here (but I believe I am right) but I think the 1500 HD is only available in LS and up,no base model available, trim so that would have a lot to do with the price also.
Frank is right, the base model 1500HD isn't comparable to the base model of the others.  Trim level is much higher as these trucks are geared more towards the general daily drivers than the real HDs are.
Creature comforts cost lots of money, as is shown in the price differences.
I think if yu were to price out a 1500HD LS and a 2500HD crewcab LS the 2500HD would be about $1000 more than the 1500HD.  (At least that was the way it was when I bought my '01)
1500HD and 2500 ext. cab also come with an automatic transmission as standard equipment, the 2500HD comes standard with a 5spd (unless it's a GMC, the give you a deduct for ordering a 5spd).
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
