2011 Silverado Front Turn Signal Bulb Replacement
Our02Silverado
Yet another process that has me dreaming about the old days. :thumbs: I'll give up my plush ride & electronic goodies for simplicity!
Anyway - it's far more of a pain in the ass than it really should be. Start by popping out those plastic retainers holding that giant plastic cover over the radiator & grille. Once you get that off you'll see what you need to remove to get the headlight assembly out (going by memory, so bear with me). Can't remember if I needed to remove the grille or not - I don't think I did. Just look carefully at how the headlight is attached. I recall having a time getting the damn thing to pop free of the fender. Stupid design, for sure.
That is what I was afraid of, having to remove the whole headlight assembly just to access the bulbs.
So, just to be clear, no way to access the turn signal bulbs other than headlight assemble removal???
Thanks!!!
I know you can get the headlight bulbs out without removal, but I recall the bulbs all the way to the side for the turnsignals were impossible to get to from the top, at least on the passenger side .... but with that said, keep in mind I've had a K & N cold-air intake system since the truck was brand new, so YMMV.
Just take a look & try to get to them, before dismantling everything. If you can't see any way to get them out, then out comes the light assembly.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
