Wtb: 03-04 Silverado Factory Fog Light Kit
ChevyMan23
I am wanting to put a set on the Silverado. I dont need bulbs, but would like to have the housings, wiring and switch. Thanks.
Check out this website. http://www.k2motor.com/03-04-chevy-silvera...ghts-clear.html
I bought a set of their smoked ones. I will warn you it says it comes complete with all hardware, wiring, and switch.
That is BS. It does not come with the 4 clips and bolts to bolt light housing onto bumper, wiring is just fine, and the switch is aftermarker, not OEM switch. That being said this kit is MUCH cheaper then trying to buy OEM lights. I bought the kit and went to the dealership and bought a factor switch (kinda pricey) $50 because I wanted OEM look on the dash. I then then took the wiring harness and cut the relay off and ran the hot wire up to the fuse block underhood and hooked it to the factory fog light relay. No one knows I added the fog's myself unless you look at the wiring down by the lights, as the harness looks a little different. I searched high and low for a fog light kit and this was all I could find.
