Silverado Climate Control Lights
shawn3091
I removed the climate control when i installed a new aftermarket radio and now that i put it all together and double checked to make sure it was plugged in right, none of the lights light up in the climate control, so i cant see it at all at night, but other than the lights it still works, what could be my problem? i also plugged stock radio back in and still didnt help
if hte controls work, but the back lighting does not...then one of the plugs is not plugged in all the way...if it doesn't work at all...check fuses and that all plugs are seated completely.
Pat
Pat
I rechecked the 2 plugs and they are in all the way and none of the pins are bent, and yes its just the back lighting that doesnt work, controls work fine
