Just Purchased 04 Denali
Just Purchased an 04 Denali with 86k Miles. I want to changed the transfer case, differentials and Tranny fluids.
Which fluids should i use? Also how difficult is it to do myself? Thanks for your responses.
Not difficult at all, just time. And use what GM spec's or better. I like synthetics for the added protection.
do not change the tranny fluid. itll tear up your tranny.
Huh? Is this true? I just changed mine recently - with the filter. Why is this the case?
It is all straight forward to accomplish. You should might find some "how to" articles in the Tech Wiki section on this forum. The transfer case will require the Auto Trak II from the dealer, 2qts are needed. The rest you can pick up at any auto parts store. The axles came with synthetic and the transmission will like stepping up to dexron VI fluid.
Fluids of choice for the differentials, AMSOIL, Mobil 1, Redline, Royal Purple.
For the ATF just go to the local auto parts and pick up some dexron VI fluid. You will need about 12qts if you do a fluid exchange. If you are just dropping the pan and changing the filter then get 6qts.
Most do not like to change out the fluid on a high mileage transmission because in most cases the transmission seems to go out shortly afterwords. I have found this to be true in my experience only when I changed out the fluid in a transmission that the fluid was really nasty and was high mileage. If the fluid is still nice and red and doesn't smell then you will not have any problems.
Also change out your Power Steering fluid as well. I used Mobil 1 ATF instead of power steering fluid. Changing the fluid made a huge difference. I would also pick up a fluid transfer pump. It will make refilling the the transfer case and differentials much easier.
x2 if the fluid is brown and burnt smelling you might have issues. If not change it out. I would not flush it. I would do a fluid exchange as shown in the how to sections.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,343 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
