Tail Light Replacement Gmt900
I backed into a grocery cart and popped a hole in the lens in my tail light :sigh: Good news is no other scrapes or scuffs, just caught the corner of the handle of the cart.
So a couple of questions... cost to replace the lens? or does the whole assembly need to be replaced?
If the whole assembly has to be replaced Im thinking of going LED. Opinions? likes/dislikes? pics??
Thanks guys and/or girls!
Not sure how it works when you replace the entire fixture, but when I replaced some regular bulbs on my old Dodge truck with LED bulbs I also had to change my flasher to an electronic flasher.
What happens is that the LEDs draw such little power that the vehicle thinks your turn signals are not working. This then causes the turn signals to blink at a much faster rate than normal.
No idea about the Sierra (have had it for only 2 days so far) but on the dodge this was an easy fix. The flasher was located in the glove box. Bought an electronic one from Auto Zone for around $12 and was done in 5 minutes.
On some vehicles you can't access it and you may have to wire in some load resistors.
You may want to look into this when considering LEDs.
Brogan i believe the LED tails are just fine and will not flash fast........... i have seen some silvys with them around town here and they flash normal. If you get some def let us know how you like them..... i have thought about doing mine
If I go with LEDs I will definitely post pics.
I was also concerned with the voltageamp draw with the LEDs compared to the standard bulbs., especially with electronics being so sensitive to voltage changes. I want to research that some more. Its a brand new truck so I dont want to do anything to void the warranty.
Thanks for all the feedback!
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
