Replacement Doors For 1999 Sierra Old Model
looking for some tech help here,,i have a 1999 sierra 2 door extended cab, old body,, and i want to replace the doors both sides,,i have found a tahoe 1999 of identical color, will the doors fit? ,,since i do not want to repaint my replacement doors, i am looking for a direct fit, ,,,what other model truck will be exact replacements that bolt right on
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
