Door Adjustment
Both front doors on my silverado are kinda "tight" and when I say tight what I mean is they are hard to shut sometimes. Nothing over strenuous when it comes to shutting them but i've closed other silverado doors with ease, along with sierras too. Sometimes they just get latched on the first click, not fully shut you know? Any adjustment on these or are my pins bad? The door has minimal up and down movement so I dont think the pins are bad but I dont know what else it could be if there isn't any adjustment.
thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
