Ford Truck Question
Trickster
Was there ever a "HULK" edition F-150 back in the late 70's? It was green and had "HULK" in white letters where the 4x4 would be today?
:lol: i dont think so........ why do you ask?
:lol: Just a random thought the other day. I was going to see how "rare" they were. I remember seeing one as a kid at my neighbor's house back in the late 70's-early 80's. It was a green F-150 4x4. Must have been custom lettering?
I too searched google, and come up with nothing.
Perhaps a custom job.
:) i dont think so........ why do you ask?
That's what I'm thinking. :driving:
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 388 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
