Transmission Fluid
I replaced my Transmission fluid today. In one of my prior posts someone told me to put dex 6. I looked in the owners manual and it calls for dex3. Why would someone tell me to do that?
Dex VI supercedes DEXIII for all GM transmissions except for certain Allison Transmissions build during 2006 and prior.
DEWFPO
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
