Will These Mirrors Work On My Truck?
No,They will not work on your '04
They will only fit '07-up GMT900 trucks.
07.5-11 are different from 00-07.5. ;)
2007 was one of those split years.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
