17" Brakes?
Could this be right? 2010 Silverado RPO list shows options JF3 and JL4 (Control - Active Brake).
I had assumed I had the standard brakes everyone seems to be complaining about. Other options include 20" Eagle LT 11 and Z85/82, 5.3, 3.42, 6 speed. I've got no complaints at all pulling a 4 x 8 4000 lb farm trailer or 18 foot lowboy.
Am I looking at an outdated RPO list? I've ordered a few things at the dealer which should be in today. When I pick them up I'm gonna ask for a build sheet.
Ted
Edit: Correct RPO from JC3 to JF3
Could this be right? 2010 Silverado RPO list shows options JC3 and JL4 (Control - Active Brake).
Ted
Iwas surprised to see GM go back to rear drums!! What happened? Are rear discs an option?
Ted
GM switched to rear drums on most 1500s in 2005. Only ones that had discs then were the 1500HDs, SS, Quadrasteer, Hybrid and Denali trucks- basically anything "special". From 07+ only the 6.0/6.2 trucks got rear discs. One of the reasons they switched was there were lots of problems with rear pad wear- on the passenger side road grit would rip up the inner pad real bad. My 03 had the inner pad down to the backing plate and the rest weren't even half worn. With the switch to drums the front rotors got larger, which is why 17" wheels are needed. People will argue till the world ends, but the drums will do a fine job of stopping the truck and trailer if it's there, and outlast the discs too. Only downside really is they're more difficult to change, esp. if you've never done them before.
Ted
No complaints with my drums... Front discs are another story
I guess I wasn't very clear with my OP. My question wasn't with drums on the rear. I just stated the RPO and search results I got.
Do the '10 Z85/Z82 trucks have 17" brakes? Or do they have 13"? Or somewhere in between?
I am making a trip to the dealer today; maybe the build sheet will help. I'm just trying to decide if a brake upgrade is needed before I get the TT I've found.
Thanks guys.
Ted
Thanks guys.
Ted
Well, if you have the 17" rims, there is no way 17" drums will fit inside them.
Ted
20" wheels with Eagle LT 11. :thumbs:
Ted
Hmm . . . you are probably right . . . I think there is a 17" spare under the bed. :cool:
I'll find something out when I get to the dealer. If the build sheet doesn't answer the question I'll yank a wheel off and measure. Maybe shoulda oughta done that to start with.
But I WANTED it to have 17" rotors/drums. :thumbs::sigh:
I sure bit on that one. Thanks guys.
Ted
Ted
I'll go ya one better....I DO have 17" rims, and mine shows 17 " drum brakes as well on my option sheet
Ted
Hah :lol: I know one way they could get those rims on over 17" brakes . . . but wouldn't KY Jelly reduce the friction on the pads to just about zero? :P
Ted
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
